Old 02-14-2006, 01:21 AM
acidrain acidrain is offline
Default Re: I just switched ti Ti racks, and had some surprising results
This run was all 7000 series parts. Normally I run 6000 series, so I know the voltage will run lower than the 6000, but it was a little surprising. From memory:
Target CD- 6 a/sf.
Timed run- 90 minutes for a .75mil ano layer.
Voltage quickly rose to only 10+ volts, stayed steady for about 20 minutes, then slowly declined for ~1 hr. In the last 10min., voltage bottomed out at 5.5v, then began to rise again. Rose to about 6v+, then dropped a bit. Wierd.
The parts came out perfect... nice deep blue dye, and no burns at the contact points.
With the 6000 series, my voltage usually rises to ~12v-13v, then is level for the entire run. If I run to a full 1mil (2hrs), it will drop off a bit in the last 15min.
My next run will be with 6000 series. We'll see if the voltage is lower with that run.
