Re: I just switched ti Ti racks, and had some surprising results
How much of the Ti is in contact with the parts? Does the Ti have pretty good tension using it that way? I have used aluminum rod like that but didn't always have good tension on the part due to the grade of some of the rods.
Have you made any runs with your pump running much of the time. The reason I ask is when I ran aeration on 6000 series the voltage ramped quickly for 15 to 20 minutes then slow climbed for the rest of the run. After changing over to an acid pump for agitation with a very aggressive flow, the fast ramp of the voltage occurs in the first 5 minutes, then slow climbs for the rest of the run.
SS
