Thread: Wiring Oven
  #25 (permalink)
Old 02-14-2006, 11:40 PM
mikekozura's Avatar
mikekozura mikekozura is offline
mikekozura is on a distinguished road
Default Re: Wiring Oven
Yes, but you have to build some kind of enclosure to house all your electrical stuff. And somewhere to mount everything. If you us a terminal block you have somewhere for your neutral and a place to grab your coil circuit and inside light from. I got the block and ground strap from one of the old ovens I used. I even used the little amber light off the old oven and but it above the thermostat dial. But it took me a while to figure out its 220 and not a regular little light bulb.I just need to cut a cover out so my ten year old don't stick his fingers in it. Check my pic.
