If you have 12" rims on a car, and you travel at X rpm...then you put on a set of 20"s (polished ofcourse!) at the same RPM, the 20s are going to GO farther in the same duration of time, but will actually make fewer rotations than the 12's...This sounds like the S.A.T's ! HAHAHAHAH..And ehhhhemmmmm....... I've been "upgraded" to Amateur. HAHAHAHAHAh
So all in all....the formula says Slower is better
