Old 02-16-2006, 09:50 PM
sswee's Avatar
sswee sswee is offline
Moderator
Default Re: What can't you save some ZoopsSeal for later?
The same reason you can't mix auto paint or clear and put it back in the can for later. Most chemicals when mixed have a pot life. The pot life is the time that a mixture can be used and function as it was designed. When chemicals are mixed one of them is usually a catalyst. When it starts its purpose there is no turning back. You could probably mix half of the contents and save the unmixed portions if you could seal them without air. I have not used the product nor familiar with its ingredients to be able to say.
SS
