Old 02-17-2006, 03:57 PM
cdnpont cdnpont is offline
cdnpont is on a distinguished road
Default Making my own Zinc Anodes?
Hello Caswell Forums,
I'm in the process of buying some CopyCad Zinc solution and brightener as I'm hoping to put together my own set-up (3 gallon). I'll be doing mostly fasteners during a automobile restoration. I have a basic power supply, and since I work on a Galvanizing line, I hope to make my own Zinc anodes (have access to 190tons of molten Zinc!). I can also get many different types of acids as well as yellow chromate solution. The nice part is that I would be able to make anodes of any size if needed.
My question is, the zinc I have access to is not absolutely pure.
It contains .125% Al and .030% Fe.
Will the percent of Aluminum and Iron present in the zinc have any real negative effect on plating that you'd know of? Does the Zinc need to be 100% pure?
Cheers, Mark.
