Old 02-20-2006, 11:07 PM
petshe25's Avatar
petshe25 petshe25 is offline
petshe25 is on a distinguished road
Default Oven Heating Problem
Ok, I've been reading alot of posts and have learned alot. The problem I have is that I have built a 4' X 4' X 6' oven and it is taking about an hour to get to 350 degrees. I have (4) 2500 watt elements running in parallel on the bottom of the oven. It is in the horizontal position with 2" insulation on all sides with inner and outer metal. When I put an amp tester on one of the 110 leads going into the box, I am getting a reading of 36 amps, but I should be getting a draw of 41.6 amps. Is this normal? I have a 50 amp service going into the oven. I would appreciate any help on this.
Pete
