Re: Oven Heating Problem
We have the same size oven and use (6) 1500W elements wired 3 phase delta, our oven takes 15 minutes to reach 400. Ours is running off a 40 amp main with a 3 pole contactor. Most people dont have 3 phase, but maybe the info helps a little. Maybe you should run (6) 2500W elements, also a circulation fan helps the oven pre-heat.
Ed
