Old 02-22-2006, 09:42 AM
pickleboy's Avatar
Default Re: Can you dip Ceramic Coating.
yes you can dip it but it is not the preferred way to do it. think about a flat sheet when you dip and pull it out the excess will start to run off. the coating at the top will be thinner than that on the bottom. if you want to do it so as to get the inside of header tubes, then the answer is yes but it will take a good amount to be able to submerse them. hope this helps bro.
