Re: Oven Heating Problem
Yep, the amps are low, you should be around 43amps at 231 volts.. it's normal to for the amps to drop a tiny bit when the element is hot but not that much. You're missing almost 7000 Btuh.
You ohm'ed the elements disconnected, correct? You might want to call the manufacturer of the elements and see what the normal resistance is..
