Old 03-01-2006, 02:08 PM
soaring soaring is offline
soaring
Default Anodizing Tank Setup ?
I am setting up a 20 gallon anodizing tank and am using 1/2" PVC pipe for my aerator. In order to keep the pipe weighted to the bottom of the tank I was planning on inserting lead strips into the tubes prior to glueing them together. Does anyone know if this will cause any issues? I reasoned that since the cathodes are lead and the tubes are filled with air during the plating process that it should not hurt but want to make sure I do not ruin my acid solution. I can also remove the aerator when not in use. Thank you for any input.
