Black Chromate for Zinc
We have a new black chromate finish for zinc plated items. It is a two part mixture of 8 ounces of A&B with distilled water which makes a gallon. It produces a harder, more uniform black finish with better adhesion. It is fast acting and gives a glossy black finish with good corrosion protection. The kit is $29.99 Operation: 1. zinc plate 2. rinse with distilled water 3. activate with 1% sulfuric acid solution 4. Rinse with distilled water 5. Immerse in A865 15-45 seconds 6. Rinse with distilled water 7. dry at 150 degrees F
