Re: de-smuting zinc die-cast
Hey Sean,
Right now I am using Washing Soda as a source of Sodium Carbonate 1/2 cups per 5 gallons water and Dawn detergent at 1/4 cups per 5 gallons.
I have tried lye but it seems to etch the die-cast if you are not careful.
I degrease in a hot tank before deoxing.
I have a proprietary product on order that has some special inhibitors to prevent zinc die-cast etching. I'll let you know how it works.
For electrodes I have tried sheet metal which wears out quickly and rebar which does not seem to have enough surface area. I have settled on stainless steel sheet which works really well. I lined 3 X 20 gallon tanks with one 4x6 ft sheet of 16 ga ss sheet. The sheet was a bit pricey at $120
If you go with the stainless steel you will need to be careful with the bath solution. Wear gloves and take your sludge to the local transfer station.
I have started using distilled water (via RO) to make up the bath, my local tap water has a lot of calcium the seems to coat the electrodes.
Dave
