Old 03-10-2006, 09:53 PM
awdmh awdmh is offline
awdmh is on a distinguished road
Default Sean, or others; carb plating question
I have a home brew zinc-plating setup. My question for you more experienced fellows is how do you effectively plate the nooks and crannies of carbs and other irregular surfaces. I deal mainly with the old Holley 94s. Many thanks, and please check out my other questions about the chromate as to temperature of the solution, ratio of DI water to powder, and type of container for solution; plastic metal, etc. It is the yellow chromate.
