Originally Posted by awdmh
What kind of acid?
Nitric is best, but can be difficult and/or costly to obtain. IF you have to have it shipped, there's a $25 hazmat fee on top of the shipping charges.
Otherwise, muriatic or sulphuric acids work, just not as well.
What kind of container do you put the chromate in?
Polypropylene or polycarbonate. I use paint mixing buckets available from local hardware stores. Pint, quart and gallon sizes are available.
What temperature do you use for the chromate?
80º for yellow. Most chromates specifiy a range, usually 70-90º, but it depends on the particular chromate.
What ratio of distilled water to chromate? The container info was vague.
Depends on the chromate, which do you have? Mine was quite clear concerning mix ratio.
Sean
