Old 03-15-2006, 12:46 AM
sswee's Avatar
sswee sswee is offline
Moderator
Default Re: Nearly burned down the shop today
Sorry to hear about your mishap but glad to hear it wasn't as bad as it could have been. There has been more than one time I worked fatigued, hit the shower and bed then had to get up, get dressed and go back to the shop to check to see if I had turned everything off because I couldn't remember for sure. With worrying about making sure there's not an operator error is a real kick in the backside when the automatic stuff fouls up. You know if you had a float valve to keep it topped off you probably would have had a sauna or the float valve would have stuck and flooded your shop. I hope your not down too long.
SS
