Need help polishing aluminum tanks
Hi,
Just got my Brown and white compound from Caswell.
I've got 3 25 foot long aluminum pontoons (like semi gas tanks) that need compounding and polishing. I'm using a variable speed commercial B&D angle buffer with a wool pad. I've used this in the past with rubbing compound with pretty good success.
This time I thought I'd buy the correct professional compound to do the job.
My problem is this, I can't get any of the brown cutting compond to adhere to the wool pad, nor will it stick to the aluminum tank. This stuff is so dry it won't stick to anything. I managed to get a bit on the pad and to shine a bit, but this can't be right. I thought that this cutting compound should be a bit greasy in order to stick the bonnet or work surface.
What am I doing wrong here?
Does the stick of compound need to be a certain temperature?
Thanks guys
Joe
