Old 03-19-2006, 09:43 AM
mpierich mpierich is offline
Default Re: Wheel Speed and scratches
Originally Posted by easleysp
I just encountered this the other day. Nothing seemed to work after a vent/emery combo so I slowed down to about 1800 rpm with a loose/white and it started looking better. Even then it wasn't to my satisfaction. However it did start looking nice when I changed locations on the wheel. Instead of using 25 degrees below center, I used the center, maybe even above center. I tried this trick a while back when I was trying to buff some scratches out next to a weld. Ya'll might think I'm nuts, but it worked both times.
Steve
Regarding the wheel speed, one thing I can figger is that the "centrifugal" effect is flinging the wheel threads out there with less force at lower speeds, hence slapping the workpiece not as hard. If that's how it works then a smaller wheel at the same rpm's might have the same effect (?).
Far as the wheel position...yep I think you're nuts but so am I, lol. Could it be that on the front side of the wheel the threads are not fighting gravity and so are more "free-floating"? Spacey territory....
Anybody know if a rheostat would burn out buffer motor?
