Re: Bending elements?
It's a good idea to run all wiring outside the shell of the oven and mount the elements at a point where the wiring hooks up to the elements within the thickness of the wall. Otherwise, you might melt the insulation and create a short circuit inside the shell. This is not speculation, I know someone who did this and ended up re-running all of his wiring on the outside after the breaker started to pop.
