Old 03-23-2006, 09:02 AM
Conrad_Turbo Conrad_Turbo is offline
Conrad_Turbo is on a distinguished road
Default Copy Cad/Zinc Plating Issues
Hello this is my first post here and I'm looking for some advice on what I am doing incorrect.
I got my kit in the other day and I finally got around to setting everything up last night. I set everything up according to the manual, the only difference was that I used deionized water instead of distilled water, which should be fine correct?
I tried to zinc plate some bolts (about 8-10 bead blasted prior to being plated) attached to a wire, and I had about 1/2 amp current for an hour which gave off light bubbles (what the manual suggested). I also previously degreased the parts according to the instructions as well.
Now the bolts that I plated, when they came out of the plating solution they were silver/zinc looking. I then rinsed them off with deionzied water and then hung them to dry. When they dried they had a white haze to them, any idea why?
I also did a small cast iron part as well; it had a pretty decent surface area so I bumped up the amperage to ¾ amp. I zinc plated it for an hour and I then rinsed it off, left it to dry and when I got back it was rusty. What happened?
Does the zinc plating bath temperature play a huge role in zinc plating quality as well? Is this due to me using deionzied water? Too much current?
-Conrad
