Old 03-24-2006, 09:30 AM
ty1295 ty1295 is offline
ty1295
Default Re: Possible to make it a 110v?
Possible sure.
The problem comes in how many amps can you supply via 110.
Typically guys are using between 350-600ish watts per cu. ft.
Your oven is 410 cu. ft. Using 350 watts per ft = 143,500 watts.
Watts/volts = amps
143,500/110 = 1,304 amps. Most house plugs are 20 amps so you only need 65 plugs, and about 10 neighbors to borrow outlets from.
Even at 220 volts in the size your talking will be almost impossible. That big of an oven generally doesn't use electric anymore but gas/propane.
