Old 03-26-2006, 05:52 PM
mpierich mpierich is offline
Default Q: Polishing and Regulations
I'm thinking of adding plating to my services (currently just polishing) since I'm learning that there are some aluminum parts that don't polish to "perfection" despite using proper techniques. A few questions for now:
1. I understand that the base metal needs to be fully polished, then pickled prior to plating. Sometimes I get a haze on aluminum that I can't get rid of, even tho the surface is fully mirrored otherwise. Will this show up after plating?
2. I read in an old post that 220 pounds or less of plating solution is considered hobby use. I would only be doing say one intake manifold or a couple of morocycle engine covers per week at the most, but doing it for the public. Would I be subject to any bothersome regulations?
3. Once the solutions are made up, do they have a shelf life? Say I do some plating then don't use the tanks for another month. Problem?
Thanks for any advice.
Mike
