Old 03-20-2003, 11:18 PM
marsfrogie marsfrogie is offline
marsfrogie
Send a message via AIM to marsfrogie
Make sure that the compound is slightly chilled. It applies to the wheel much better when it is less than 60 degrees. Press the greaseless compound against a wheel spinning at about 2000 RPM's until the wheel is completely coated with red compound. If you leave the wheel running the compound will dry faster. It should be ready to use in about 5 minutes if you leave the wheel running. Should last for about 5-15 minutes of use before another application is required.
