Old 03-26-2006, 08:54 PM
fly fly is offline
Default Re: Q: Polishing and Regulations
1. No the plating will cover the haze up.
2. As long as you do it by the book you will be ok, but it depends on the situation. The EPA is a good association, you just have to figure out how you want to set your shop up...
3. No the solutions will be good as long as you keep them at the proper ratio, and you will need to keep up the chemical ratio after periods of use. When the baths get heated to operating temp. the water will evaporate and you have to add back what has evaporated. THats why when you build the bath for the first time you need to mark the level so you know how much water to add back...
