Re: Stripping anodizing
any suggestions on airflow/pressure requirements?
The pencil blaster caswell sells shows 1.5cfm at 80psi.. but that seems low to me.. I'm assuming I could use more pressure with the same setup?
I'm not doing a ton of work like this, so I hate to spend a ton to get it set up. (I already have a suitable compressor..)
Assuming it is well mask and I'm careful about blast direction.. will the anodizing remaining be prone to chipping? I would think not, but I've never taken it off, just put it on.
Kyle
