Re: Rectifier
I read most of all that also when I first started. Then was lucky enough to be able to talk with Fibergeek. He helped me straighten out my start up problems.
You said you were attempting a run of 1.5 SF of SA, what was the amperage you were trying to use on that batch?
Watch out changing too many things at once, it could make it hard to tell where the real problem is.
SS
