Thread: Rectitier
  #17 (permalink)
Old 03-27-2006, 01:13 AM
-AAPB-Eric -AAPB-Eric is offline
-AAPB-Eric is on a distinguished road
Default Re: Rectitier
Originally Posted by sswee
Tank set up looks good. I'd recommend at least a 12g wire for your cathode hook ups. I used the aligator clips at first but it don't take much natural oxide on the alum. to cause connection problems. From the pics, you just need to refine your set up a little. What are you using for agitation?
SS
12g insulated copper I pick up tomorow! I could have too much oxide on the actual plates since they did have a buildup of the chauky white acid residue (left them in the tank for 1 day to build up the dissolved AL content), Ill rub down with some steel wool and see if that makes a difference.
Yes, so far we have been spending 3 weeks on cleaning up my cluttered garage and setting up the buffing, ano tanks etc. The tank will soon have some Ti racks and all Ti wires for the connections to help eliminate lost connections (cant really use the sput welder since the parts need to be in prime condition). The agitation so far are 2 of the caswell agitatiors. I really like them so ill pick up 2 more so 1 for each corner. I have some 120 L aquarium airpumps that are ok at pumping out bubbles, ill leave those for my dye tanks.
