Originally Posted by TreyY
sweet thanks for the support. And Mike you can be sure that I will be asking some questions. And I am pretty sure that it is going to be single phase and Im thinking of building it the same way as you Mike, except mine would lay on the ground and be 6' long instead of high. So are the 4 1500W elements enough to heat that up? Also how thick are your walls. Is 1inch thick insulation enough are is it better to go with 2inch thick?
Four 1500w elements will be fine. I would go with no less then 2" of insulation. That ridge Owens Corning #703 I used was nice it stands up by it self and you can cut it with a hand saw. It was a little hard to find here in Pittsburgh, PA (home of the Steelers). I found a commercial supply place that sold c.o.d to the public.
http://www.hamiltongv.com/
I can't seem to get the powder coat oven site to come up.
http://www.powdercoatoven.4t.com
Whats up Gary where's the site... Hope it's not gone forever....
Also this is a good thread to read over
Wiring Oven
