Re: copper tank problems
First off you need air (bubbles) to agitate the bath, and you need to use the 4x6 anodes, space them about 2" apart and 2 on each side of the tank. Take your part that your going to plate and measure the square inches and mulitply it by 0.1 and take you answer and turn you rectifier to that and then see what happens...you might not have enough brightner and you need to have the bath tested for the proper ratio....
