Re: primary chain cover prep help
the easy off is only needed if the part is previously anodized. as for your case i would start around 220-240 grit and see if that is coming smooth if not back up to 180. always start at around 200 grit unless you see deep scratches or road rash. this will keep you from doing more work than needed.
