Id like to thank SSWEE, everything in a smaller tank (5gal) is working now!
Well, since Im just starting out, it takes me a while to do the anodizing process. I have broken it down to two days/parts. 1st is degreaser tank, strip the old anodized layer (paintball markers), clean, deox and buff.
Now, here is my question. how long can these parts be laying around? when will rust start to develop? these parts are wet and being air dryed and hanging around for around a week maybe two.
I have taken no chances with my first few anodizing batches, after this process I dunk my parts in a degreaser and then deox. I have noticed that my parts are slightly etched coming out of the deox, can I skip this step since I already did this prior to the buffing?
2nd thing is connection problems. I would be anodizing just fine and when I slightly ramp up my volts (which in turn ups the amps) I loose my connections. I have been using both 20g AL wire doubled up and ti wire. The ti wire is working well but where can I get firmer ti wire? Can the current of the agitator bump the parts and cause a lost connection? I am doing this at 9ASF, will listen to Caswell and try to do 6 ASF and see if that is a bit more gentle on my parts.
for fun, these 2 items on the left and middle have been anodized and was my first sucessful anodizing run.
