Old 04-03-2006, 07:47 PM
mpierich mpierich is offline
Default Re: Need advice on a Grinder
Originally Posted by JeffL
Where did you get that formula? The formula on the buffing & polishing booklet says....1/4xDia. of wheelxrpm.That would give me 6900 sfpm. on an 8" wheel. And 5250 on a 12" wheel.But it is certain that which ever formula is used, the 12" wheel is going to spin slower.Am I still going to benefit using the bigger grinder at slower speeds, but being able to put more pressure on the part, & making more heat?
Jeff,
There is no way that the larger wheel is moving slower (at the same rpm's) on the same machine. They are moving at the exact same rpm's - and since the larger wheel's surface has to travel farther in the same time, it's surface will be moving at a _faster_ fpm (feet per minute).
8": 1/4 x 8" = 2.....2 x 3450 rpm = 6,900 fpm.
12": 1/4 x 12" = 3....3 x 3450 rpm = 10,350 fpm.
Be careful...several of us feel that excessive wheels speeds makes it very dificult to achieve a good final color.
Unless you mean it'll move slower when you lean on it - that's very possible since the larger diameter gives you more leverage relative to the center of the wheel.
