  #9 (permalink)
Old 04-04-2006, 02:57 PM
mpierich mpierich is offline
Default Re: Need advice on a Grinder
Originally Posted by JeffL
Sorry for not clarifying my answer.The 12" wheel is spinning at 1750rpm on a 2hp grinder. The 8" wheel spinning at 3450 on a 3/4hp grinder.....thats why sfpm are slower. Was wondering if it was worth putting out the money for another grinder, or putting the money toward something else.
Whatever you get, the more HP the better, and the longer the shaft the better for clearance. 3/4 HP is a little weak. Also, since most of your work will be on the underside of the wheel, hanging the motor from an arm will give you the best clearance of all. And don't forget about the apparent problems of excessive surface speed for coloring. I'm heading toward a two-speed motor or a dual pulley system for that reason.
