Thread: white haze
Old 04-05-2006, 08:15 PM
fly fly is offline
Default Re: white haze
Can you give me the exact steps that you took on the part after you did the water test after cleaning.
You can get by without filtering the solution, I don't filter mine and it does good, but filtering is better for the bath..
Make sure you have the correct temp. (140degree) agitation, and correct amps. I will be able to help more with more information.
