Thread: white haze
Old 04-06-2006, 08:58 PM
fly fly is offline
Default Re: white haze
It looks like you need to go up on your amps, try .1 per square inch for about 15 min. and then see.
Take the part and polish it with white compound and flannel cotton wheel and try it again..
You realy would be better off using the flash copper and then go to the nickel...
If the niokle is thick enough then you can go ahead and chrome plate the part after you polish it, but if you do that then you need to go with blue compound and flannel cotton after the white/flannel cotton.
Sorry about the temp difference I use a different company and they said run the temp at 140, maybe you should try that.....
