Originally Posted by cdaeme
Another with Door to check temps. I used 1 1/2" Mineral Wool Insulation covered with Aluminim Foil. Applied Drywall cornerbead to all joining edges. Foil Tape on all seams. The next step is to relocate the broil element to the inside surface of the door and rewire it to there using flex conduit from the back around the side and into the side of the door. What do you think?
Jason
Auto-Cycle PC
i used good insulation on the outside ,do i have to insulate the inside,also what type of wire did you use to wire the broiler to the bottom ,i assume you wired it to the bottom correct.
