Re: Helpful Tip : FISH EYES OR WHATEVER
I always use a torch to ge the part stripped down, then blast it with my bead blaster then hang it. I use a stuff found at napa called prep clean. I spray that in there then use my torch and lightly heat it off. You can watch the moisture run out of the metal, then coat. Seams to work for me.
