Old 04-11-2006, 06:20 AM
mpierich mpierich is offline
Default Re: newbie with questions...
Originally Posted by Annihilator
hello all, been trolling around for a little bit here, seems like a lot of good info here, so I figured it'd be best to ask the experts
I have just recently started working on a crossbrace for my 01 pontiac grand prix gtp, and was wondering what you guys suggest I do from here...
I have removed all of the black coating off of it with a wire brush (that took forever to get those stupid crevices and imperfection areas)...and have sanded with 50 grit, and 100 grit...I have 220 grit, as well as 800 and 1000, but which other grits should I go buy? Also, do you guys have any suggestions on what to use to seal the metal when it is finished? I have heard zoop seal works really well, and I have some mother's mag & aluminum polish (also heard some good things about this)...but the crossbrace is stamped steel, so I'd like to use something that will prevent it from rusting the longest time possible while still looking good.
also, I know absolutely nothing about polishing wheels, I've been using hand sandpaper + elbow grease to this point. I have a dremel tool (only one speed) as well as an air compressor which I assume would be able to do a much better job than the dremel...
edit - or do you guys think that I should just stop where I am and paint the crossbraces? I don't want to do all of the work just to realize it's going to rust up in a week...
I'd paint or powdercoat it myself, if it's steel. They have powder in "hillbilly chrome" if you want it to look a lilttle fancy.
