Re: Need Help polishing large flat section
There is an adaptor you can get to put regular wheels onto an angle grinder - I believe Caswell sells them - look in the polishing section. Personally I think the grinder is too fast, but some guys in here do use them and apparently like them.
For a slower speed tool, why not use your wheels on an air drill with a mandrel? Or, you could get a flex shaft on an electric motor.
