Re: Just trying to figure out everything I need to start PC
A sandblaster is best for prep but sanding will work as well. You have to make sure all of the existing paint/coating is removed. All rust and grime also has to be removed.
You don't need a large compressor for the powder coater. However if you want to use it for sandblasting you will need a large compressor. I've seen $50 coleman compressors at Pep-Boys that would work well for the PC gun.
