Old 04-12-2006, 10:52 PM
sswee's Avatar
sswee sswee is offline
Moderator
Default Re: control amps by cathode size
A CC/CV PS will have knobs to adjust voltage and current. The method you are describing is CV anodizing. Setting the voltage and letting the current flow as the circuit allows. To use this method you need to titrate your tank so you know and can adjust your aluminum content of your electrolyte and the acid concentration.
SS
