Originally Posted by emopunk96
Is there any other ways to prep but sand blasting? Iv seen guys on the forums heat up some solution and soak the part in it? What about using like a sanding wheel power tool or something? Isnt the point just to clean off the part of grease/debris ect?
-nick
there are other ways but blasting is the best. as for the point being to clean off the part the answer is yes and more so no. the point is to give the part a profile that will give the powder a bite or grip on the part as it cure and bonds to the base.
