  #15 (permalink)
Old 04-15-2006, 03:51 PM
KZjim's Avatar
KZjim KZjim is offline
KZjim is on a distinguished road
Send a message via Yahoo to KZjim
Default Re: Sandblasting and prepping, newb help me!
Originally Posted by emopunk96
Is there any other ways to prep but sand blasting? Iv seen guys on the forums heat up some solution and soak the part in it? What about using like a sanding wheel power tool or something? Isnt the point just to clean off the part of grease/debris ect?
-nick
Bottom line is, time vs. effort...yes a sanding wheel will work, but how much time will you spend using that vs. soaking vs. the blasting cabinet?...
Heated solvent just screams toxic issues to me...
it takes just a few minutes to get a valve cover clean in the blast cabinet.... look at it this way.. everybody uses them... it must work.
If it jams; Force it. And if it breaks it needed replacing anyway.
I can go from 0 to "What seems to be the problem Officer?" in 3 seconds."
