Re: cleaning questions
Lacquer thinner and a toothbrush should have taken it right off. Often times I go at the final polish with Mothers mag wheel polish by hand, and it also melts if off. After Mothers, hit it with lacquer thinner (I've been told acetone works even better), then follow that with Caswells's SP degreaser until it passes the water break test. Maybe you left out that last step?
