Re: Low Voltage
I'm calculating your surface area to be 70.69 sq in. You didn't say what current density you're using - working backward from the 2.6 amps it looks like you're using 5.3 a/ft2?
Someone with more experience will probably have some better ideas, but it looks to me like you're not getting good agitation. You might also try lowering the CD to 4.5 to get a smaller pore size.
