Re: Air agitation or pump?
I use a little giant TE-5-MD-HC for aggitation in my tank, I have around 20 gallons and this pump will cycle the entire thing about once a mintue, you could go with a smaller pump with no trouble, i found agood deal on this one so i purchased it
Get a Magnetic drive Little Giant and you will be set, remove the grease before you plumb it in
When you get a pump I would go with the HC (highly corrosive) the hc models do not cost a lot more, and give you a piece of mind How big is your tank ?
