Old 04-18-2006, 06:54 PM
rclint rclint is offline
rclint is an unknown quantity at this point
Default Re: Difference in "colour" of anodized parts
Originally Posted by anodizeme4ever
The current dropped to zero, voltage remained at around 27.
Do you not think the platess are the issue?
It sounds like you have lost connection (which is common problems) the anodize layer builds up and reduces the onnection between the wire and the part, anodize layer (aluminum oxide) is a constant fight with the wire connection if the connection is not perfect
You were running in constant current mode right ?
Clint
