Old 04-01-2003, 09:34 PM
mcaswell's Avatar
mcaswell mcaswell is offline
Caswell Inc Founder
It's all about SFPM:
For best results your wheel should maintain a surface speed of between 3600 & 7500 Surface Feet Per Minute. (SFPM). The higher your speed, the better and quicker your results.
Formula for calculating surface speed of wheel in SFPM.
SFPM = 1/4 x diameter of Wheel x RPM (revs of spindle per min.)
Therefore an 8" wheel @ 3600 RPM =2 x 3600 = 7200SFPM.
However, your drill may not be able to spin 6" or 8" wheels because it may not have enough power. If you can press a wheel against the part you're buffing without stopping the motor, you're safe.
Have A Web Site?
