Originally Posted by anodizeme4ever
Yes, using 20 amp, 30 volt CC/CV Digital Rectifier. I had the wires wedged in the threaded holes. Could it be they reached PAR?
kevin
Nope, the current should have been whatever you set it at. make sure you had it in constant current mode (the rectifier) if so then you lost connection. A threaded connection works pretty good, and a spring type connection that the tips of the wire will engrave the piece to be anodized, that's what kind of force we are talking when having a good connection, even then it can fail. The sput welder is a sure thing, but threaded and spring tension also works.
Clint
