Old 04-20-2006, 05:22 PM
RedRiver RedRiver is offline
Default I need to strip chrome from aluminum?
Hi all...It's my first time here. Be patient, I'm destined to screw up somehow...lol
Anyway, I've been doing some type II aluminum anodizing for quite some time now with terrific results. I started with small and slowly moved my way up to a larger scale setup (40 gal tanks). I do a fair number of paintball markers and have not yet come across a hitch - until today. I've done oodles of markers and when it came to do my own, I hit a stump! To present, I have always stripped the original anodic layer off with Caswell's anodizing & chrome stripper. Thus far this has been fruitfull but today when I when to strip what I believe to be chrome of my trigger (aluminum base metal), I couldn't get it to work (I've never tried stripping chrome before).
I should also mention that this chrome has a tinge of brownish to it and fingerprints are often left in a sort of bluish hue. What I think is chrome may be something else but I really believe it is chrome (perhaps nickle) plated.
What I did is as follows :
Using the Caswell anodizing & chrome stripper at room temperature (71F), I connected the negative lead of my 12 battery charger to a steel cathode and the positive lead to the chrome plated trigger. I submerged the cathode and the trigger into the solution and let sit for what seemed like forever. Running the battery charger at 12v and 2 amps the cathode and trigger both bubbled immesley, however, the chrome did not appear to come off the trigger. I should note that the steel cathode did turn black.
My questions to you are :
1. Doesn't chrome have nickle underneath?
2. Is it possible that the chrome has been stripped and I am left with the nickle at this point?
3. Once the chrome is gone, how do you remove the nickle? I need to strip this baby down right to the bare aluminum.
Thanks for any help you can send my way...I'm really stuck on this one!
